Removal of speaker cover on beovision 5
Chaka
Chicago
Posts 312
Chaka Posted: Thu, Mar 27 2014 12:58 PM
Hello,
Can somebody please tell me how to remove the front cloth cover on a beovision 5?  I don't want to rip it off and damage it or the frame etc.
Many thanks.
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Thu, Mar 27 2014 2:04 PM
Pull the frame off carefully but forcefully (its only held on with clips) - then you'll see the screws holding the speaker cover (and the board it's attached to). Remove these and the cover simply lifts off.
Lee
Chaka
Chicago
Posts 312
Chaka replied on Thu, Mar 27 2014 9:39 PM
Thank you very much Lee.
Easy job.
There was a slight noticeable sound coming from the unit noticeable at low levels.
I thought it may be the fans needing replacement, but sound is coming from the plasma screen buttons on the bottom left of screen.
Probably just due to age I guess.
Thanks again, saved me a service visit. Wink
Page 1 of 1 (3 items) | RSS
