Hello,
Can somebody please tell me how to remove the front cloth cover on a beovision 5? I don't want to rip it off and damage it or the frame etc.
Many thanks.
Pull the frame off carefully but forcefully (its only held on with clips) - then you'll see the screws holding the speaker cover (and the board it's attached to). Remove these and the cover simply lifts off.
Lee
Thank you very much Lee.
Easy job.
There was a slight noticeable sound coming from the unit noticeable at low levels.
I thought it may be the fans needing replacement, but sound is coming from the plasma screen buttons on the bottom left of screen.
Probably just due to age I guess.
Thanks again, saved me a service visit.
