BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
As you no doubt know, it was designed to operate with the AV9000 television. The quick and easy answer is no, it won't act like the Ouverture as a stand alone unit and has to be connected to the AV9000 TV. The MPAV 9000 does not have any Powerlink sockets nor ordinary speaker outlets and just relies on the masterlink type connection to the AV9000 TV for sound output. This connection is not the same as the normal Masterlink either!
However, I do seem to recall someone making an internal modification to one (probably by installing Ouverture parts) to make it operate but it would be an expensive option.
Dave.
