MPAV 9000 - Ouverture
mr_anders_son
sweden
Posts 1,710
mr_anders_son Posted: Sat, Apr 12 2014 12:35 PM
Will MPAV 9000 act same as Ouverture stand alone?
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Dave Farr
France
Posts 2,283
Dave Farr replied on Sat, Apr 12 2014 2:08 PM
As you no doubt know, it was designed to operate with the AV9000 television.  The quick and easy answer is no, it won't act like the Ouverture as a stand alone unit and has to be connected to the AV9000 TV.  The MPAV 9000 does not have any Powerlink sockets nor ordinary speaker outlets and just relies on the masterlink type connection to the AV9000 TV for sound output.  This connection is not the same as the normal Masterlink either!
However, I do seem to recall someone making an internal modification to one (probably by installing Ouverture parts) to make it operate but it would be an expensive option.
Dave.
kai
Posts 362
kai replied on Sun, Apr 13 2014 12:43 AM
Hi I know it can be done as I have that I have that unit and it's still working I Adli modified one for a customer when I work for Bango, the biggest problem now is cost, back then it was different but now for the cost you can pick up a 2nd hand overture or beosound 3000 for between £250 and for £400 so personally not worth it anymore
Page 1 of 1 (3 items) | RSS
