Hello
I know it happened to some beoworlders but no one explained why.
one of my beolab 8000 stay green. i tried with different cables and with Left or right, still the same issue.
Sometimes the led is red and when it receives a signal it becomes green , but no sound.
I opened the beolab 8000, checked the connectors of the amp and make some cleaning, but still the same issue.
The other one works perfectly. They have been stored for 2 months in a garage.
Thank you in advance for your help
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
For information, I don't hear any relay clicking and the foam inside is falling and is sticky.
I have swaped the amps between the two beolab 8000 and it seems that the problem is coming from the amp only.
Any clue ?
Hi
I am really surprised that nobody on beoworld can help me to explain this behaviour.
BR
Did you ever resolve this problem? I am having the same problem. By the way, how do you remove the wiring which goes to the plugs at the bottom?
Thank you.
Gary
