Transporting a BV10??
gk31ax
Posts 19
gk31ax Posted: Mon, Apr 28 2014 12:24 PM
Hello All
It's been a fair while since I've posted.
Can anyone tell me if it's safe to transport a BV10-40 in original packing on its side or does it have to be upright? for a trip down the motorway?
I've searched the forum and can only find and article relating to plasmas which I was already aware of
Thanks in advance
Gary
Mr 10Percent
So West, Its Now East
Posts 591
Tell you that I moved house recently.......
Wrap the TV in the flat thin foam sheet that comes with it.
Then this: http://www.homemovingboxes.co.uk/ProdInfo.aspx?Stock-Code=FE60-80  2.5 lengths can be cut to frame the TV
Then bubble wrap, then finally flat packing boxes binding all the above.
Transport vertically.
Worked for me.
10
Millemissen
Flensborg, Denmark
Posts 14,680
Why so complicated?
A couple of thick blankets would do it - just lay it flat...and drive carefull.
The Beonic Man
Bristol
Posts 812
It's only plasma TVs that 'used to' need to be transported vertically, not LCDs, and that was some years ago now. Although still recommended to transport a plasma upright it will still be fine if you leave it for a few hours in the upright position before turning on. The BV10 is LCD so you have no concerns.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.
11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Mr 10Percent
Posts 591
Didn't have any blankets.
Plenty of bubble wrap though
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Fri, May 2 2014 7:52 PM
Had the same question two years ago and asked my B&O store which said it was no issues at all to transport it flat and so I did. Short 40 min ride on the highway to new location.
Page 1 of 1 (6 items) | RSS
