Hello All
It's been a fair while since I've posted.
Can anyone tell me if it's safe to transport a BV10-40 in original packing on its side or does it have to be upright? for a trip down the motorway?
I've searched the forum and can only find and article relating to plasmas which I was already aware of
Thanks in advance
Gary
Tell you that I moved house recently.......
Wrap the TV in the flat thin foam sheet that comes with it.
Then this: http://www.homemovingboxes.co.uk/ProdInfo.aspx?Stock-Code=FE60-80 2.5 lengths can be cut to frame the TV
Then bubble wrap, then finally flat packing boxes binding all the above.
Transport vertically.
Worked for me.
10
Why so complicated?
A couple of thick blankets would do it - just lay it flat...and drive carefull.
It's only plasma TVs that 'used to' need to be transported vertically, not LCDs, and that was some years ago now. Although still recommended to transport a plasma upright it will still be fine if you leave it for a few hours in the upright position before turning on. The BV10 is LCD so you have no concerns.
B&O products are V1-32, BS2, H95, E8 and an Essence remote.11-46 now replaced with Sony A90J 65”, Sony HT-A9, Sony UBP-X800M2 and Sony SRS-NS7.
Didn't have any blankets.
Plenty of bubble wrap though
Had the same question two years ago and asked my B&O store which said it was no issues at all to transport it flat and so I did. Short 40 min ride on the highway to new location.
