Please tell your experience with the good things and the bad .. about matrix
Thank you very much
claudiu:Please tell your experience with the good things and the bad .. about matrixThank you very much
I use matrix 8x8, but not all families like to use beo 6 ,and have big problems using beo4.
to open the dvd: example. V.AUX2 - GO -0-2-GO-0
have to be very good and fast fingers so you can open dvd with beo4
even when using Beolink app to open a matrix zone need to enter GO-0 after you have pressed the button that opens the dvd .Is normal?
yes use beosystem platform BeoVision 9, 8, 10
Yes I saw this on another new platform, you can enter tv, dtv or whatever.
makes it possible to use much easier beo4 .
claudiu:I use matrix 8x8, but not all families like to use beo 6 ,and have big problems using beo4. to open the dvd: example. V.AUX2 - GO -0-2-GO-0 have to be very good and fast fingers so you can open dvd with beo4
beo 4 works well with the new platform beosystem 4.
but it seems that they have no interest whatsoever to create the same system for beosystem 3
they say you have to use beo6., but now no longer produce beo6 was removed from the market
If you need macros or if you just want your older B&O video chassis's to preform better in conjunction with the Atlona matrix system you could always just get a MLGW.
The newer chassis's can handle all of the needed commands in one button press on a Beo4.
Atlona matrix systems are relatively bullet-proof. I have only experienced issues where people cheap out on the proper cables to them, or if it is a MKI Pro product. All others are near flawless.
Ah, you know... A little B&O here, a little there
Is anybody using the Atlona H2H-44M (88M) HDMI Matrix switcher?
If so, do they work properly?
What about the matrix wiring/programming? You just connect all PUC devices to matrix inputs and your Beovisions to the outputs - that`s simple...
But how does puc wiring and -programming work?
Stefan
what exactly is an Atlona Matrix ? And what is it used for?
MH
stefan: Is anybody using the Atlona H2H-44M (88M) HDMI Matrix switcher? If so, do they work properly? What about the matrix wiring/programming? You just connect all PUC devices to matrix inputs and your Beovisions to the outputs - that`s simple... But how does puc wiring and -programming work? Thanks Stefan
Nobody?
I would have thought that at least dealers/installers on the forum can give some advice.....(?)
Atlona works great with all B&O kit. Update your TV puc and connect a puc cable to control the Matrix & Cat Balin receiver that you will get with your Matrix. From there run your cat connections to the Matrix. Connect all video and ir cables from your devices to the Matrix system itself. Turn on and enjoy :)
Thanks for the replies. As I understand it, sources will be connected to IR-OUT 1-4 for PUC control and displays i.e. Beovisions to IR-IN 1-4 on a PRO3 switch, right?
I`m referring to 44M versions..
So, an Atlona H2H won`t work, as it ha no IR sockets. My initial question was referring to the H2H-44M.
Or will it work adding the HDXX-IR transmitter/receiver?
I would like to add the H2H version, as it`s less boxes and less cabling (I don`t need more than 15m HDMI in most cases)
A bit confusing for me is the V.AUX - GO - 02 - GO.....message.
Did anybody got the system working on a BS3 based system by activating sources (and controlling sources) by just one press, as we all are used to
control Beosystems`
