Hi all,
Long time no post.................. :-(
I have a Blue AV5 that I have finally done something with and I would like to connect some Blue Beolab 3000's that are spare in the same room.
I've tried connecting the ML to a MCL/ML (?) box to try and convert the sound to PL (or even passive) and nothing seems to work.
Is it possible to add Active or Passive speakers to an AV5?
Do I need a speaker with ML? ( I used to have a Beocentre and a BL2000 connected directly via ML and it worked fine)
Any hints and tips would be appreciated.
Cheers
PS, It's amazing how much of this stuff you can forget!!!!
Many years ago when I got my BL1's, they were connected to my AV5 through a Beolink Active box, so it can be done.
Hi Henrik, thanks for that, makes sense and I've connected one, although I just need to get hold of a IR sensor now.......... Cheers
