BeoVision AV5 with additional external speakers - can t be done?
Large48
Posts 32
Large48 Posted: Tue, May 20 2014 5:31 PM
Hi all,
Long time no post.................. :-(
I have a Blue AV5 that I have finally done something with and I would like to connect some Blue Beolab 3000's that are spare in the same room.
I've tried connecting the ML to a MCL/ML (?) box to try and convert the sound to PL (or even passive) and nothing seems to work.
Is it possible to add Active or Passive speakers to an AV5?
Do I need a speaker with ML? ( I used to have a Beocentre and a BL2000 connected directly via ML and it worked fine)
Any hints and tips would be appreciated.
Cheers
PS, It's amazing how much of this stuff you can forget!!!!
  • Filed under:
Henrik Toubro
Copenhagen
Posts 70
Many years ago when I got my BL1's, they were connected to my AV5 through a Beolink Active box, so it can be done.
Large48
Posts 32
Large48 replied on Fri, May 23 2014 8:08 AM
Hi Henrik, thanks for that, makes sense and I've connected one, although I just need to get hold of a IR sensor now.......... Cheers
Page 1 of 1 (3 items) | RSS
