Help needed with Beocenter 7002 record player
redrovery
Posts 6
redrovery Posted: Sat, May 24 2014 1:53 PM
Hello,
I need some help with my Beocenter 7002 record player. It was working perfectly until this morning, I lifted the stlus arm on the record player to remove some dust and the arm is now stuck to the right. There feels to be a lot of tension in the arm and pressing the phono or other buttons does not work.
So far I have turned that player off and tried to adjust the counterweight but no luck.
Please can you help?
Richard
Sorted, after a while it seemed to reset and tension went, plays perfectly now. Thanks anyway:-)
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 24 2014 3:31 PM
In cases like this, when the mech. comes "out of sync" or has stopped mid-cycle for unknown reasons, it can
often be a good idea to carefully rotate the platter by hand (normal direction, clockwise as seen from above).
This will often bring everything back in "sync".
redrovery
Posts 6
redrovery replied on Sun, May 25 2014 8:54 PM
Thank you very much Martin, its working now. But I will know what to do next time. Thanks again.
Page 1 of 1 (3 items) | RSS
