Hello,
I need some help with my Beocenter 7002 record player. It was working perfectly until this morning, I lifted the stlus arm on the record player to remove some dust and the arm is now stuck to the right. There feels to be a lot of tension in the arm and pressing the phono or other buttons does not work.
So far I have turned that player off and tried to adjust the counterweight but no luck.
Please can you help?
Richard
Sorted, after a while it seemed to reset and tension went, plays perfectly now. Thanks anyway:-)
In cases like this, when the mech. comes "out of sync" or has stopped mid-cycle for unknown reasons, it canoften be a good idea to carefully rotate the platter by hand (normal direction, clockwise as seen from above).This will often bring everything back in "sync".
Thank you very much Martin, its working now. But I will know what to do next time. Thanks again.
