Is there any way for a DVD1 to be configured to operate via Beo4 without a connected Beovision?
Hi kokomo,
I am afraid that it won't work without a BV connected as the DVD1 has no ir-receptor (the signal normaly gets routed from the BV through the scart cable to the DVD1). To my knowledge the DVD1 also has no connections for an external ir-eye.
So no good news... sorry
Foxtrott
"The first thing we do, let's kill all the lawyers."
William Shakespeare, Henry VI, Part 2, Act 4
Thought not, but worth asking just in case there was.
Thanks for that.
Would it be possible with a -238 ? Just an idea. I have in mind that someone used one pin of the scart cable to send remote commands, but I'm not sure about that.
BeoSound 9000 MK3, BeoLab 8000, BeoLab 6000, BeoLab 3500, LCS9000, BeoLab 11, BeoLab 7.2, BeoLab 7.1, Beolab 4 PC, BeoCenter 2300, BeoSound Century, BeoSound 8, Beosound 2, BeoVision 7-40 MK2 , BeoVision 7-32 MK3, BeoVision 6-22, BeoVision 4-42, BeoMedia 1, BeoCom 4, BeoLink 1000, BeoLink 5, BeoLink 4 & BeoTime
Possibly - Pin 8 and Ground are used to transmit the signals out of a beovision so presumably they are used to receive - the -238 is a converter though so I would imagine you would have to configure it to send and receive b&o commands - or would an ir eye at the right frequency connected to Pin8 and Ground do the same thing?
You may be able to configure a -238 to receive philips or some other remote control commands and then convert them into B&O DVD conmmands and transmit these directly into a DVD1 via scart?
