Detailed photos wanted of relay used in Beogram 1203
LesleyV
Posts 7
LesleyV Posted: Mon, Apr 20 2020 11:55 AM
Hello Guys,
One of the wires in the plastic relay box had a bad connection, reason why I opened the box to resolder the wire.
But then the two black plastic levers fell out. I managed to put them back but i want to make sure i did this correct.
Reason why i would like to have some detailed pictures, especially from the side shown in the picture so I can determine how the lever has to be placed in relation to the contacts.
Thanks,
Lesley
Dillen
Copenhagen / Denmark
Posts 13,191
LesleyV
Posts 7
I saw this one but it did not help me. I have another version of this relay, one without springs on the outside. For now i put the contacts (see red dots on the pic) on the outer side of the lever but i am not sure it is right.Reason why i wanted a detailed pic.
LesleyV
Posts 7
LesleyV replied on Wed, Apr 22 2020 9:18 PM
Hi guys,
This position I have chosen for the lever (see pic) seems to be correct because everything is working fine. The only problem left is that the turntabe is running a bit too slow but retores itself after 5-10 minutes.So case closed so far.
Page 1 of 1 (4 items) | RSS
