Projector out : how to keep a listening preset when using FORMAT 0 ?
olvisab
Posts 1,391
olvisab Posted: Wed, Nov 26 2014 2:34 PM
When I select "format 0" I have the picture that goes from the bv to another tv but I lost my listening preset (5 surround speakers) It should be the same with a projector.
However, I keep the listening preset when the picture come back to the b&o tv.(after having modified the wrong listening preset)
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
hfat
Vienna, Austria
Posts 663
hfat replied on Wed, Nov 26 2014 3:31 PM
Hi olvisab,
It's easy: When you are in Format 0 (cinema) mode, just enter the menu. You will discover that alle the sound setting are renamed to "Cinema" instead to "TV". Setup the setting as you like and store them. In my case the cinema position is different from the TV position, so I had to set different settings.
hfat
olvisab
Posts 1,391
olvisab replied on Wed, Nov 26 2014 4:02 PM
Thanks hfat, I will try it.
Page 1 of 1 (3 items) | RSS
