4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Hi olvisab,
It's easy: When you are in Format 0 (cinema) mode, just enter the menu. You will discover that alle the sound setting are renamed to "Cinema" instead to "TV". Setup the setting as you like and store them. In my case the cinema position is different from the TV position, so I had to set different settings.
hfat
