beocord 9000
This post has 15 Replies | 2 Followers
lotus73jps
Posts 141
lotus73jps Posted: Mon, Aug 25 2014 1:13 PM
hi I have a beocord 9000 which I brought from new ive just renewed the belts and roller all seems to work ok but cannot record or play prerecording tapes and peakprogamme meter recording level indicator do not light up would be greatfull for any advice
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Aug 25 2014 1:30 PM
Does the motor run ?
lotus73jps
Posts 141
hi martin yes I can fast forward rewind and play every thing seems to work
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 25 2014 2:28 PM
Methinks you forgot to plug the replay/rec head's connector back!
Jacques
lotus73jps
Posts 141
hi chartz  all I done was change the belts did not touch any thing else but were would I look to check the head connector thanks
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 25 2014 2:42 PM
Here: check that you didn't accidentally pull the connectors, see the one at right!
Jacques
lotus73jps
Posts 141
hi chartz thanks I will check and get back to you
lotus73jps
Posts 141
hi Jacques ived looked but no loose connectors
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 25 2014 3:29 PM
Okay then. Let's wait for John's or Martin's comments!
Jacques
lotus73jps
Posts 141
thanks
Søren Mexico
Mexico City
Posts 6,411
Cleaning plugs and jacks (connectors) in my BC 5000 solved nearly all my problems
Dillen
Posts 13,191
Dillen replied on Mon, Aug 25 2014 9:58 PM
I am not sure if I understand the question:
You typically cannot record onto a prerecorded tape, because the small record protection taps are
missing on prerecorded tapes to protect the recording from accidental erasure.
In the good old days we put a piece of scotch tape where the tap would be.
Just don't cover the nearby CrO2 detector opening - on Chrome tapes that is.
lotus73jps
Posts 141
lotus73jps replied on Mon, Aug 25 2014 11:21 PM
hi martin Icannot playprerecorded taps and cannot record on blank taps there is no ppm showing whith a blank tap I press rec open press record no ppm showing press record it starts to record but the tape is blank at the end off recording Ihave tried it whith my beomaster 8000 whith my beomaster 6000 and even whith my beocenter 9500 but stll get the same results no ppm showing look forewardto hearing from you
sonavor
Texas, United States
Posts 3,732
sonavor replied on Tue, Aug 26 2014 12:26 AM
To clarify what has been stated about the problem -
This was a working Beocord 9000 cassette deck, then you changed the belts and the thrust roller (that presses the tape to the capstan), and now you can't record or playback tapes?
You can operate fast forward, rewind and play and verify that those operations do turn the cassette properly. You just don't get any sound when operating playback and you can't get a record signal into the deck.
Check that you didn't accidently set the Line/DIN switch on the underside of the deck to DIN (like I did). Make sure it is set to Line.
If the deck is operating the cassette correctly and you have verified the deck switches are correct, then it sounds like your problem is in the electronics or a connection to the electronics.
sonavor
Posts 3,732
sonavor replied on Tue, Aug 26 2014 2:16 AM
You may have already done this but double-check the position of the switch located in front next to the headphones jack. Make sure it is set to the Amplifier position (not AUX or MIC).
lotus73jps
Posts 141
hi sonavar the line/din switch is set to line plus the other switch is set to amp if it is the electronics is there any way off testing or is it a job for b&o thanks hope to hear from you soon
Page 1 of 1 (16 items) | RSS
