Link TV Question BV7-32 to BC6-23
This post has 22 Replies | 3 Followers
AndrewEcosse
Posts 77
AndrewEcosse Posted: Wed, Sep 10 2014 7:26 PM
Hi, I'm about to purchase a BC6-23 to act as a link tv to a BV7-32. I currently have an old Sky HD box connected to the BV7 via the component for picture and scart for the sound. The question is what will I get on the BC6? As far as I know the component will not be shared to the BC6 but the scary will. So will it automatically pick up the picture and sound?? With a link TV do I get the same control over connections in the menu or is that all pulled from the main tv?
Any help would be appreciated.
Andrew.
butch1
Posts 384
butch1 replied on Wed, Sep 10 2014 8:20 PM
Hi you connect masterlink cable between the 2 ,for control and sound,also you connect aerial from rf out on bv7 to rf in on bc6 this gives you composite video,you then can control your main sources connected on your bv7 in your link room.
the bc6 can control the stb box from the main room and dvd from bv7.
AndrewEcosse
Posts 77
Ok that's great. So will the Component video be shared or the SCART? I was worried it as the BV7 is set to use the Component video that it would only share the sound to the BV6.
All very confusing all this. :-)
butch1
Posts 384
butch1 replied on Thu, Sep 11 2014 11:06 AM
The masterlink cable carries the sound,you only get composite video through the aerial lead,any hd source will be converted to composite.
AndrewEcosse
Posts 77
I also have a MacMini connected via the DVI, but from what i'm being told that will not be shared? Is that the case?
Thanks for your help with this.
Douglas
Edinburgh & Essen, Germany
Posts 58
Douglas replied on Thu, Sep 11 2014 11:12 AM
Hi, the scart signal is converted to a RF signal (aerial) for masterlink picture and sound, if you press AV & then source you will then get the sound over the masterlink cable as stereo!
regards DC
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Sep 11 2014 12:07 PM
butch1:
No, it's not.
Several STB's can provide both analoge (SD, composite and/or scart) and digital (DVI or HDMI) simultaniously. Connect both.
Video through the (link)coax can only be done with RGB or Composite (via scart). Any source (DVI, Component) on the AV4 (vertical placed connections on the right side) are not available on the link.
Beobuddy
Posts 3,972
butch1:
No, it's not.
AndrewEcosse
Posts 77
Ok, so no matter how I have the BV7 set up. As in to view the RGB and not the SCART, the SCART video will be available on the Coax to the BC6?
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Sep 11 2014 2:55 PM
Beobuddy:
No, it's not.
In general this is correct.
But the inbuild sources (HD module and Bluray player of BV 7) can be viewed also on a Link-TV. They are obviously connected digital and also analogue inside Beovisions. Regarding the Bluray player you'll get picture only in SD on Main-TV when watching a bluray on Link-TV at the same time.
Regards
Räuber
butch1
Posts 384
butch1 replied on Thu, Sep 11 2014 5:43 PM
Please tell me how a hd source in main room run through a rf aerial lead,produces the same hd picture in the link room?
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Sep 11 2014 5:52 PM
butch1:
In link room you get only a picture with SD quality. But the picture quality is better than recordings from harddisc recorder HDR2 which is directly connected to link room tv.
I'm using a BV 10-40 in my link room and the viewing distance is about 5 meters. I'm really happy with picture quality when watching videos from main room, although it's not HD.
Regards
Räuber
Beobuddy
Posts 3,972
Beobuddy replied on Thu, Sep 11 2014 7:18 PM
Raeuber:
So, that's a typical difference if you have in mind that a BV7 has a "stripped" version of the system 3 (with the later mk's)
My BV9 (with system 3) can only display a HD content at it's screen and SD version of that on a link tv when both SD and HD are connected. But by choosing the same source on a link tv, the BV9's panel stays in HD quality.
Raeuber
Germany
Posts 2,542
Raeuber replied on Thu, Sep 11 2014 9:41 PM
Beobuddy:
Same with my BV 7-40 Mk6 (as far as I know it has not a"stripped" but a "full" Beosystem 3) together with an EXTERNAL Bluray player (or any other device connected both via HDMI and Scart). The behaviour I described was with the INBUILT Bluray player.
Greets
Räuber
butch1
Posts 384
butch1 replied on Thu, Sep 11 2014 10:34 PM
You never answered my question,
I will tell you, that a local connected source ie stb connected by scart to link tv,will give you a better picture than a stb signal from main room sent through rf.
I have 4 beocenter 6s running off 2 system master tvs and the link picture is not as good as a stb box connected locally to the tvs with scart.
Raeuber
Germany
Posts 2,542
Raeuber replied on Fri, Sep 12 2014 5:25 AM
butch1:
Hello butch1,
this is not my experience. I would say the picture quality is the same. But it depends on the following:
- quality and lenght of antenna cable between main and link tv,
- a "good" link frequency setted up in the connection menues,
- if using more than one link tv, you have to use an amplifier, especielly the RF link amplifier from B&O to connect up to 4 Link-tvs.
As already mentioned: When watching recordings I get a better picture when using the harddisk recorder (Technisat) connected to main room tv than HDR2 connected via scart to link room tv. But this may depend on the bad quality of HDR2.
A few weeks ago I had a technician in my house who was very surprised of the good picture quality of my link tv, because he couldn't get such a good quality when setting up a link tv at another customer.
Regards
Räuber
AndrewEcosse
Posts 77
Right so all arrived and installed. And in general all great. Picture is fine for a non HD set and seems to be improved watching a HD station. A couple of questions though....
How come I cannot get the radio to work through the BV7? Is the link only one way? Also one thing i'd not expected, while the picture was always not going to work for the MacMini, why is the sound not working either? It used to work perfectly with the BL3500. I tried today putting the sound through one of the scarts and again no luck. Any ideas?
Thanks, Andrew.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sun, Sep 14 2014 6:46 PM
Hi Andrew,
you can select all sources connected to main room tv (BV7) at your link tv (BC6), but not the other way round. So you are right, Masterlink works only one way.
If your Mac mini is connected to BV7 you should hear the sound also at BC6 if sound is available (also) analogue (via scart or cinch). The sound is provided via masterlink cable in stereo. If you don't get sound, check the following:
If you select your BV7 HD video source (also connected analogue) at BC6, you get a SD picture and mono sound, both provided by the antenna cable. If you want to check if you can get stereo sound via masterlink cable, use AV command and then press the source button on Beo4 to get access to the source connected to BV7. If you get only picture but no sound, the masterlink connection is faulty. That would be also the reason why you don't get sound from your Mac mini although it's connected analogue at BV7.
Regards
Räuber
AndrewEcosse
Posts 77
Ah ok, so I need some sort of video from the mac to Scart to be able to select it on the BV6. I'm going to get a DVI to S-Video and connect that to the scart and see what happens.
I'll test the master link now, but I do get sound from the in built Freeview and DVD to the BV6.
Thanks for your help.
Andrew.
AndrewEcosse
Posts 77
Ok this is driving me mad.... Getting an analogue out from the Mac Mini is proving difficult. If I use a VGA connection to the TV will that get shared to the BV6? Oddly if I connect the photo to the scart and set it up as AV2, I get the sound shared for a second and then it cuts out???
I find it amazing there seems to be no way to get this to work easily.
Thanks, Andrew.
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Sep 20 2014 6:21 AM
Hi Andrew,
I'm not an expert regarding Mac Mini. To give you some advice please tell me;
- Which cables do you use to connect Mac Mini to BV 7-32?
- Do you have the actual Mac Mini as shown on Apple's homepage?
Regards
Räuber
AndrewEcosse
Posts 77
Hi Räuber,
Thank you for your help with this. The Mac is connected to the BV7 via mini DVI to DVI and the audio is from the headphone socket to the phono in on the BV7. The mac also has a mini display port, but seems that will not goto s-video either.
Below is the model I have. It's a late 2009 MacMini.
http://zapp0.staticworld.net/reviews/graphics/products/uploaded/405138_g2.jpg
Raeuber
Germany
Posts 2,542
Raeuber replied on Sat, Sep 20 2014 8:59 AM
Hi Andrew,
you can't get a picture on your link tv because DVI is a digital connection.
To get sound on link tv connect headphone output of Mac Mini with R/L line-in of BV 7. I took a look into manual of BV 7-32, R/L line-in is available at AV 4. You can also use audio input of camera connection on top side of BV 7. Use a cable like this:
http://www.amazon.de/Hama-Audio-Kabel-Cinch-Stecker-Klinken-Stecker-Frustfreie/dp/B007M6N61A/ref=sr_1_2?ie=UTF8&qid=1411199037&sr=8-2&keywords=kopfhörer+cinch
Hope this helps.
If you can't get sound, check headphone output of Mac Mini by using a headphone.
Greets
Räuber
Page 1 of 1 (23 items) | RSS
