Replacement woofer s45-2
This post has 7 Replies | 0 Followers
gavinbray
Posts 6
gavinbray Posted: Tue, Oct 14 2014 7:24 PM
Hello,I have a problem with one of my s45-2s,basically it sounds like the foam has gone on the woofer but it is fine. Am trying to find out what the problem is on another thread,but if I need to replace the woofer,what is the best one to go for ?
Thank you
Gavin.
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Tue, Oct 14 2014 11:20 PM
Sounds like the magnet has slipped. It's fixable, do a search on the forums, there was a thread about it recently.
Dave Farr
France
Posts 2,283
Dave Farr replied on Wed, Oct 15 2014 8:49 AM
Lee:
This is one such short thread of a successful repair but there are others:
http://archivedforum2.beoworld.org/forums/p/4738/43309.aspx#43309
and this is the most informative one for a proper fix:
http://archivedforum2.beoworld.org/forums/p/1243/10546.aspx#10546
Dave.
gavinbray
Posts 6
gavinbray replied on Wed, Oct 15 2014 4:02 PM
Thank you. I'm not overly confidant as I have never fixed a woofer before but will give it a go. If it doesn't work which woofer would be a good replacement ? I read somewhere Goldwood woofers would do the trick.
Cheers
Gavin.
Peter
Earsdon
Posts 11,991
Peter replied on Wed, Oct 15 2014 8:58 PM
If you are not confident, get it done professionally. One of my M100 woofers did the same and i had it repaired. Company in Norfolk.
Peter
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Thu, Oct 16 2014 8:27 PM
Most times you can buy a pair for peanuts (at least here in Holland) which is probably cheaper then getting it repaired.
Maybe I have one left...
From what I know S45-2 woofer have rubber surrounds?
Brengen & Ophalen
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Fri, Oct 17 2014 5:55 PM
Leslie:
Mine do.
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Oct 17 2014 6:28 PM
They do have a rubber surround. The later series uniphase S45 had a foam surround but that was a completely different two way speaker.
Peter
Page 1 of 1 (8 items) | RSS
