Hello,I have a problem with one of my s45-2s,basically it sounds like the foam has gone on the woofer but it is fine. Am trying to find out what the problem is on another thread,but if I need to replace the woofer,what is the best one to go for ?
Thank you
Gavin.
Sounds like the magnet has slipped. It's fixable, do a search on the forums, there was a thread about it recently.
Lee: Sounds like the magnet has slipped. It's fixable, do a search on the forums, there was a thread about it recently.
This is one such short thread of a successful repair but there are others:
http://archivedforum2.beoworld.org/forums/p/4738/43309.aspx#43309
and this is the most informative one for a proper fix:
http://archivedforum2.beoworld.org/forums/p/1243/10546.aspx#10546
Dave.
Thank you. I'm not overly confidant as I have never fixed a woofer before but will give it a go. If it doesn't work which woofer would be a good replacement ? I read somewhere Goldwood woofers would do the trick.
Cheers
If you are not confident, get it done professionally. One of my M100 woofers did the same and i had it repaired. Company in Norfolk.
Peter
Most times you can buy a pair for peanuts (at least here in Holland) which is probably cheaper then getting it repaired.
Maybe I have one left...
From what I know S45-2 woofer have rubber surrounds?
Brengen & Ophalen
Leslie: From what I know S45-2 woofer have rubber surrounds?
Mine do.
They do have a rubber surround. The later series uniphase S45 had a foam surround but that was a completely different two way speaker.
