Beogram 9500
This post has 7 Replies | 0 Followers
Master_Geek
Posts 79
Master_Geek Posted: Tue, Oct 28 2014 12:20 PM
I have motiver that when playing a record and I put ny ear very close to the PU, I can hear music from the PUi itself. Is this normal?
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Tue, Oct 28 2014 12:27 PM
I assume PU is the Pick-Up...
It's completely normal to hear the music from the pick-up.. all stylus and cartridges do this.. some are louder than others. It's just the way they work...
Lee
Lee
Posts 734
-Deleted Duplicate-
Master_Geek
Posts 79
Thanks for your Quick answer :)
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Oct 28 2014 12:38 PM
As 'Lee' has said, this is quite normal. If you play the Beogram without the amp on, you will hear it quite clearly to the extent that you should be able to identify the music.  It's just the transfer of the vibrations.  All the amp effectively does is amplify that vibration and convert it to sound from the speakers.
No need to worry.
Dave.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 28 2014 7:14 PM
You've now discovered why amplifiers and speakers are needed.
Master_Geek
Posts 79
And BTW, would a weight clamp improve the overall sound?
Dillen
Posts 13,191
Dillen replied on Wed, Oct 29 2014 7:43 AM
No.
It would prevent the suspension from doing its job as intended and put a damaging axial load on the main bearing.
Page 1 of 1 (8 items) | RSS
