I am thinking of upgrading my AV9000 and getting a BV7-32, I don't want a large TV in the lounge so thought the 32 would be a good size.
I have been offered a Mk3 set by a friend who has one he has not used in a while.
What are the things to take into consideration with this tv?
Toby
Hi Toby,
it only has a single HDMI input. Check the inputs to make sure it covers your requirements.
The MK3's are cheap at the moment - check the ones at Lifestyle AV for a rough guide.
32" may not be big enough for you in the longer term and you may be better with the 40". See if you can look at one.
Also, does it come with a Beolab centre speaker? Stand or wall bracket? They are of course getting old by now. The picture on your AV9000 will still match up quite well to the 7-32. I know mine does.
Dave.
Sorry Ralf, you're right, mixing up my connections.
Thank you for the replies.
I went to have a look at the TV last night unfortunately one of the corners had a mark that would not come off. Think I will wait until we have our building work done and then decide what TV to get, may be look at a 40 inch set (even though I have a stand for a 7-32 (brought for my BV6) and a BL7.1 (currently used with a non B&O TV)
