Beovision 7-32
This post has 5 Replies | 0 Followers
badgersurf
Posts 539
badgersurf Posted: Thu, Oct 23 2014 4:07 PM
I am thinking of upgrading my AV9000 and getting a BV7-32, I don't want a large TV in the lounge so thought the 32 would be a good size.
I have been offered a Mk3 set by a friend who has one he has not used in a while.
What are the things to take into consideration with this tv?
Toby
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Oct 23 2014 5:58 PM
Hi Toby,
it only has a single HDMI input.  Check the inputs to make sure it covers your requirements.
The MK3's are cheap at the moment - check the ones at Lifestyle AV for a rough guide.
32" may not be big enough for you in the longer term and you may be better with the 40".  See if you can look at one.
Also, does it come with a Beolab centre speaker?  Stand or wall bracket? They are of course getting old by now.  The picture on your AV9000 will still match up quite well to the 7-32.  I know mine does.
Dave.
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Oct 23 2014 6:05 PM
Actually MK III has no HDMI, just DVI.
I got one and use DVI for HD TV and YPbPr (component) for Playstation 720p.
It works great.
Have it on the motorised stand with Beolab 7-1 - upgraded from the Beocenter 6-26.
Check serial number before buying to ensure the TV is hd ready.
Ralf
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Oct 23 2014 6:06 PM
sorry for the bad quality of the photo, old ipad...
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Oct 23 2014 6:30 PM
Sorry Ralf, you're right, mixing up my connections.
Dave.
badgersurf
Posts 539
Thank you for the replies.
I went to have a look at the TV last night unfortunately one of the corners had a mark that would not come off. Think I will wait until we have our building work done and then decide what TV to get, may be look at a 40 inch set (even though I have a stand for a 7-32 (brought for my BV6) and a BL7.1 (currently used with a non B&O TV)
Toby
Page 1 of 1 (6 items) | RSS
