Unable to activate V.AUX from linkroom
This post has 3 Replies | 0 Followers
Hiort
Sweden
Posts 2,895
Hiort Posted: Tue, Nov 18 2014 4:01 PM
I have a BL3500 in a linkroom, in the following setup:
Everything works fine, but not the following:
I want to activate Playmaker from the linkroom.
Playmaker is configured to A.AUX "button", through the BV11 and NL/ML converter. Activating A.AUX from main room works fine. If A.AUX already is activated in Main room, it works just to press on BL3500 to play whats on the linksystem.
Activating A.AUX from the linkroom just open the AUX port on BC2, so that is no joy.
When I try to trigger V.AUX from the linkroom (I use Beolink 1000 remote) i press "SHIFT" + "TV". The only thing that happens is that the display on the BL3500 flicker quickly from V-AUX to TV then to standby.
Any advice?
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Nov 18 2014 7:05 PM
try using ATAPE (=AMEM)
in the NL-ML converter: I presume the ML role is set to V master; goto Configuration -  IR MAPPING
IR command: AMEM
 NLproductname = Beolink Converter (or your alias of the converter)
NL source= LINE IN
My setup BV11-BLC1-with BS5e on line in - BS5; the BS5e is activated on AMEM=ATAPE
Hiort
Sweden
Posts 2,895
I followed your instructions, but no joy.
I currently have the below settings and still A.AUX only open the A.AUX on the BC2.
Any more advise?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Nov 25 2014 3:12 PM
If I understand it correctly, you can only select audio sources of your audiomaster  from linkrooms (via ML).
Playmaker can`t be an audiomaster.
Question: Does your BL3500 support "A.AUX - V.AUX!. `d check the sw. Newest must be 3.4 afaik. It`s the one for MLGW to send/receive LIGHT/CONTROL commands.
Stefan
Page 1 of 1 (4 items) | RSS
