I have a BL3500 in a linkroom, in the following setup:
Everything works fine, but not the following:
I want to activate Playmaker from the linkroom.
Playmaker is configured to A.AUX "button", through the BV11 and NL/ML converter. Activating A.AUX from main room works fine. If A.AUX already is activated in Main room, it works just to press on BL3500 to play whats on the linksystem.
Activating A.AUX from the linkroom just open the AUX port on BC2, so that is no joy.
When I try to trigger V.AUX from the linkroom (I use Beolink 1000 remote) i press "SHIFT" + "TV". The only thing that happens is that the display on the BL3500 flicker quickly from V-AUX to TV then to standby.
Any advice?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
try using ATAPE (=AMEM)
in the NL-ML converter: I presume the ML role is set to V master; goto Configuration - IR MAPPING
IR command: AMEM
NLproductname = Beolink Converter (or your alias of the converter)
NL source= LINE IN
My setup BV11-BLC1-with BS5e on line in - BS5; the BS5e is activated on AMEM=ATAPE
I followed your instructions, but no joy.
I currently have the below settings and still A.AUX only open the A.AUX on the BC2.
Any more advise?
If I understand it correctly, you can only select audio sources of your audiomaster from linkrooms (via ML).
Playmaker can`t be an audiomaster.
Question: Does your BL3500 support "A.AUX - V.AUX!. `d check the sw. Newest must be 3.4 afaik. It`s the one for MLGW to send/receive LIGHT/CONTROL commands.
Stefan
