dear members,
one of my Beogram 4002 tables causes the following problem:
after I pulled the motor apart for a lube service and change of a blown fuse
the platter now decided to spin anti-clockwise ??
plugs are all in place correctly....but what could cause that kind of problem ?
any ideas anybody ??
thanks for your replies :-))
I'm afraid I'll go with the obvious guess that you didn't assemble the motor correctly...
Is it AC or DC motor version?
--mika
hi mika,
it is the AC motor version !
there is really nothing that one could do wrong in the re-assembly process, couldn't one ?!?!
no loose parts, except its cover !
unscrew the cap, lubricate the motor and close it again ???
or did I miss anything ?
Does it turn counterclockwise any time? Does the platter rotate on its own?
Methinks you might have put the magnet upside down when you re-assembled the motor.
Jacques
Yes, spin anti-clockwise when turned on.
I will check the motor assembly again - nothing is impossible
Thanks for the thought anyway
Cheers, Alf
the ac motor is re-assembled correctly - there is only one way
cheers, alf
