Beogram 4002 platter spins anti-clockwise
This post has 5 Replies | 0 Followers
ALF
AUS
Posts 1,015
Silver Member
ALF Posted: Fri, Nov 28 2014 1:11 PM
dear members,
one of my Beogram 4002 tables causes the following problem:
after I pulled the motor apart for a lube service and change of a blown fuse
the platter now decided  to spin anti-clockwise ??
plugs are all in place correctly....but what could cause that kind of problem ?
any ideas anybody ??
thanks for your replies :-))
tournedos
Finland
Posts 7,357
tournedos replied on Fri, Nov 28 2014 1:14 PM
I'm afraid I'll go with the obvious guess that you didn't assemble the motor correctly...
Is it AC or DC motor version?
--mika
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sat, Nov 29 2014 12:59 AM
hi mika,
it is the AC motor version !
there is really nothing that one could do wrong in the re-assembly process, couldn't one ?!?!
no loose parts, except its cover !
unscrew the cap, lubricate the motor and close it again ???
or did I miss anything ?
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Nov 29 2014 8:17 AM
Does it turn counterclockwise any time? Does the platter rotate on its own?
Methinks you might have put the magnet upside down when you re-assembled the motor.
Jacques
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Sat, Nov 29 2014 3:24 PM
Yes, spin anti-clockwise  when turned on.
I will check the motor assembly again - nothing is impossible
Thanks for the thought anyway
Cheers, Alf
ALF
AUS
Posts 1,015
Silver Member
ALF replied on Fri, Dec 5 2014 9:50 AM
the ac motor is re-assembled correctly - there is only one way Big Smile
cheers, alf
Page 1 of 1 (6 items) | RSS
