Motorised TV Hinges: B&O is a bargain!
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger Posted: Wed, Dec 17 2014 11:50 AM
Look at what you get for £1400 if you want a motorised hinge for a non- B&O TV.
Video here.
Makes me feel that my motorised BV11 hinge was a really elegant bargain!
Graham
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Wed, Dec 17 2014 4:58 PM
That one goes off the wall as well as turning.
If think it's a nice kit. Seems much quicker than the B&O.
w5bno123
London
Posts 578
w5bno123 replied on Wed, Dec 17 2014 6:06 PM
It might be quicker but they are also a lot noisier than the B&O brackets. Bit like the tortoise and hare story...Wink
tournedos
Finland
Posts 7,357
tournedos replied on Wed, Dec 17 2014 6:44 PM
It's very silent on the video Big Smile
--mika
w5bno123
London
Posts 578
w5bno123 replied on Wed, Dec 17 2014 7:16 PM
tournedos:
--mika
It won't make a difference how loud you play the video. I've installed these and they are a bit clunky in real life.
MartinW
Posts 389
MartinW replied on Fri, Dec 19 2014 12:45 AM
I had one of those for my old 10-46. It stuck out loads from the wall, was very very noisy, and would never go back parallel with the wall - you had to push it the last inch manually!
It did do the job, but yes - not even comparable to a B&O bracket which is just perfection - and nearly twice the price of B&O too.
It wasn't any quicker but travelled in a different way - like an Avant bracket, not a BV11.
vikinger
Posts 5,422
vikinger replied on Fri, Dec 19 2014 8:11 AM
MartinW:
I think that the Avant type centre hinge and the BV11 type edge hinge (not to mention the floor and table stands) are really difficult to beat when it comes to elegant appearance and operation.
You could get a large Smart TV for under £600 and add one of these £1400 brackets. So for around £2000 you can have a clunky two remote system with poor sound quality.  Or for around double that get a beautifully finished fully integrated smooth operating B&O TV with outstanding sound and picture.
The B&O offerings look better and better value all the time.
Graham
Page 1 of 1 (7 items) | RSS
