Beomaster 2000 is not stable. Without a clear cause it switches off. It may play for an hour or less, then switches off. Sometimes it's only matter of minutes.
I already took the device apart, (which is rather complicated), in order to check power supply. That seems OK: 42 VDC +/-, and 27 VDC (relais coil tension)
I wonder if this defect could be a failing STK amp module, or whether the sensor switches and the surroudings electronics are the culprit.
Any assistance would be very much appreciated.
Bad electrolytic capacitors?
Bad solderings?
