Beomaster 2000 switches "off" at irregular intervals
This post has 1 Reply | 0 Followers
Berre
Posts 1
Berre Posted: Thu, Dec 18 2014 4:17 PM
Beomaster 2000 is not stable.  Without a clear cause it switches off.  It may play for an hour or less, then switches off. Sometimes it's only  matter of minutes.
I already took the device apart, (which is rather complicated), in order to check power supply.  That seems OK: 42 VDC +/-, and 27 VDC (relais coil tension)
I wonder if this defect could be a failing STK amp module, or whether the sensor switches and the surroudings electronics are the culprit.
Any assistance would be very much appreciated.
Premiumverum
Netherlands
Posts 115
Bad electrolytic capacitors?
Bad solderings?
Page 1 of 1 (2 items) | RSS
