Bang Olufsen App DLNA Playback
This post has 3 Replies | 0 Followers
Beosince98
Posts 274
Beosince98 Posted: Sat, Aug 18 2018 1:40 PM
I have a DLNA Server in my network and want to play music to my Beovision Avant via the App. I can access the music via Homemedia and play it directly on the TV, but I find that not very convenient. I can see the DLNA collection in the app, but if I want to play It on the Avant, it does not work. Any tips?
Thank you as always!
Sandyb
Posts 2,186
Sandyb replied on Sat, Aug 18 2018 3:41 PM
You need a music product like a Moment or a Core / Essence I believe.
You will then be able to see that music system as a product in the app, and use the Avant speakers (the music system will need to be set to use the Avant as it's default speaker).
If you don't fancy adding a Moment etc, a separate speaker / system like an A9 or A6, or one of the new BS 1/2 work with DLNA direct from the app.
Unfortunately the Avant won't, hence the need for something additional
Beosince98
Posts 274
Thank you for your help! That is very strange, as I don't believe that there is a technical reason for this.
Millemissen
Flensborg, Denmark
Posts 14,680
Untill a previous sw version the tv acted as a DLNA renderer - means you could play to it.
There has been previous threads about this.
It is something that the guys in Struer know - if there will be a change again, is still uncertain.
The Bang & Olufsen app is mainly meant for the audio products.
However it would be nice, if the app would support the Avant/2014 too.
Please write Beocare a note - the more people asking for this, the better.
Page 1 of 1 (4 items) | RSS
