Beosound Essence??
striker27
Posts 64
striker27 Posted: Mon, Jan 5 2015 7:13 AM
I have a fairly nice set up now via ML.  Beosound 4000 master a few passive 1658's with the IR eye for control as well as a Beolab 2000 and 3500...     I was hoping to integrate a Essence into the equation but I know this may be possible through the AUX jack on the Beosound 4000....   Would I have full control to distribute sound from the  Essence over my entire network???
Another question could I use the Essence alone with a B&O passive and use my own speakers in another separate location????     If so how would it be accomplished?
Sorry for the questions..
leosgonewild
Helsinki, Finland
Posts 2,373
Are you planning to use the Essence as a stand-alone source for Spotify, or are you planning to use it together with an iPhone or Mac?
I have been trying to figure out a way to incorporate a essence with my vintage setup, but in the end it will only give me a expensive remote.
With the vintage systems, in my opinion, it is better to go with an airport express or maybe a playmaker (I do not know the playmaker very well).
The Essence is a cool remote control, that's about it :( (and I hate myself for saying that)
Millemissen
Flensborg, Denmark
Posts 14,680
striker27:
Don't feel sorry for the questions - but do feel sorry for not searching the forum before posting Unsure
This question (and similar) has been asked quite a few times now - most recently in a thread started just 2 days ago.
Please have a look there:
http://archivedforum2.beoworld.org/forums/t/13316.aspx
As with any other BeoSound/BeoCenter with PowerLink as the speakers connection you can easily use a BeoLink Passive for driving any (well almost any) passive speakers.
Just connect the PL-out of the Essence to the PL-in on the BL Passive amp - you don't need the 'ir-eye' connected.
And you will have to use a - fully wired - RJ/PL to DIN/PL cable (or an adapter), since the plug of the PL has been changed.
All newer B&O devices have the RJ/PL connections.
Do feel free to ask further questions after reading the thread mentioned above Smile
P.S. For the europeans amongst the Beoworlders - a BS4000 is what we call a BeoSound Ouverture!
Page 1 of 1 (3 items) | RSS
