Dear fans,
For the Beoremote one owners : can you get access to "light" by pressing one button (like the beo4 light button) ?
Does a "mybutton" can be used for that fonction ?
I don't whant an argument at home if I bring the new remote and it's a pain to use compared to the old one...
You can add "Light" to the "List" button at the top right of the remote. And you can make it the first in the list. So that means you can get "light" in one button.
But you probably can't do "light"-"light" as on the Beo4.
Note that I do not own a BeoRemote (yet!), I am saying this based on what's been said here by others and reading the manual. Just ask your dealer for a demo before buying it.
Beoworld app with direct photo upload and emoticons.
i have the Beoremote one with an LC 2.
You can added the "light" to a "mybutton" and then press by a number (1-9).
Press "Stop/Pause" you switched the light off.
Regards
(sorry for my english)
Ligth (= 1 press on List) followed by a press on the OK button at the center of the arrows should also work to turn the lights on. But to be tested.
ButziBaer: i have the Beoremote one with an LC 2. You can added the "light" to a "mybutton" and then press by a number (1-9). Press "Stop/Pause" you switched the light off.
I have the same setup. A BeoRemote One programmed to use one of the mybuttons as a LIGHT-button instead (the middle one - as it was in the middle on Beo4). You don't have to use the mybuttons for your TV, you can use them to choose regular sources also :).
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael:you can use them to choose regular sources also
Including "Light"?
PhilLondon: Michael:you can use them to choose regular sources also Including "Light"?
Yes. To adjust light I simply take my BeoRemote One, press the middle "my button" and dim down or up the light. No need to select Light in LIST or anything.
