Beoremote one and light control LC2
BeoGreg
South of France
Posts 1,417
BeoGreg Posted: Thu, Jan 8 2015 9:29 AM
Dear fans,
For the Beoremote one owners : can you get access to "light" by pressing one button (like the beo4 light button) ?
Does a "mybutton" can be used for that fonction ?
I don't whant an argument at home if I bring the new remote and it's a pain to use compared to the old one...
PhilLondon
London
Posts 3,637
You can add "Light" to the "List" button at the top right of the remote. And you can make it the first in the list. So that means you can get "light" in one button.
But you probably can't do "light"-"light" as on the Beo4.
Note that I do not own a BeoRemote (yet!), I am saying this based on what's been said here by others and reading the manual. Just ask your dealer for a demo before buying it.
Beoworld app with direct photo upload and emoticons.
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Thu, Jan 8 2015 10:24 AM
Thanks.
What I'll have to try is light followed by a number (1-9).
That's what I do with beo4, light + light or light + 5 for example for tv viewing.
So even with beo4 there are two pressings on the remote to get light.
On the Beoremote one should be three then or two if magically light appears after "list" + "light".
But I think of something else, I want "stand" on pole position in list not light.
Will ask my dealer if we can have light with a mybutton.
ButziBaer
Posts 12
ButziBaer replied on Thu, Jan 8 2015 10:56 AM
i have the Beoremote one with an LC 2.
You can added the "light" to a "mybutton" and then press by a number (1-9).
Press "Stop/Pause" you switched the light off.
Regards
(sorry for my english)
PhilLondon
London
Posts 3,637
Ligth (= 1 press on List) followed by a press on the OK button at the center of the arrows should also work to turn the lights on. But to be tested.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Jan 8 2015 11:57 AM
ButziBaer:
I have the same setup. A BeoRemote One programmed to use one of the mybuttons as a LIGHT-button instead (the middle one - as it was in the middle on Beo4). You don't have to use the mybuttons for your TV, you can use them to choose regular sources also :).
PhilLondon
London
Posts 3,637
Michael:
Including "Light"?
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Thu, Jan 8 2015 2:36 PM
Thanks guys, I think I will get a Beoremote one then with light mybutton.
Silk or not silk that is the question ! And a shame there is no holder available.
Michael
Sweden
Posts 2,578
Michael replied on Thu, Jan 8 2015 5:06 PM
PhilLondon:
Michael:
Including "Light"?
Yes. To adjust light I simply take my BeoRemote One, press the middle "my button" and dim down or up the light. No need to select Light in LIST or anything.
Page 1 of 1 (9 items) | RSS
