Hi all
Would a premade cat6 cable be ok for lab12 or should I buy per made cat7.
I will be cutting one end off and soldering on power link for one end.
Eclipse 65V1-32Beosound M5Essence MK2BLI
Cat6 should be ok for everyone, as long as you're not needing 100m...
diisign.com
cat 6 is fine but if you use a Cat6 utp cable it won't work. only the ftp cable work because they are shielded.
Hi there
So if i order some pre made cat6 STP cables and cut one end off and solder on PowerLink this will work ok
does anyone have the pin configuration for this?
