Lab 12 speaker cable
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, May 30 2012 9:42 PM
Hi all
Would a premade cat6 cable be ok for lab12 or should I buy per made cat7.
I will be cutting one end off and soldering on power link for one end.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mbee
Paris, France
Posts 1,842
mbee replied on Wed, May 30 2012 10:11 PM
Cat6 should be ok for everyone, as long as you're not needing 100m...
1983beo
Posts 127
1983beo replied on Thu, May 31 2012 10:55 AM
cat 6 is fine but if you use a Cat6 utp cable it won't work. only the ftp cable work because they are shielded.
Seanie_230
UK
Posts 2,278
Hi there
So if i order some pre made cat6 STP cables and cut one end off and solder on PowerLink this will work ok
does anyone have the pin configuration for this?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Page 1 of 1 (4 items) | RSS
