I will sell my BS 5 and buy the Moment. Does anyone have experience with the NL-ML converter?
Beovision 7-55" 3D, Beosound 5, Beolab 9, Beolab 8000, Beovision 6, Beo 6, Beoremote one, H8, H2.
http://archivedforum2.beoworld.org/forums/p/14245/124588.aspx
There are some minor issues. I bought mine about two weeks ago. It is working very well beside the linkroom issues mentioned in the link.
gabriel:Does anyone have experience with the NL-ML converter
The possibility to use the Moment in a masterlink and/or networklink will be coming around 15 May with a automatic software upgrade.
Until that day you can only connect to ONE source.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Chris: gabriel:Does anyone have experience with the NL-ML converter The possibility to use the Moment in a masterlink and/or networklink will be coming around 15 May with a automatic software upgrade. Until that day you can only connect to ONE source.
Thats correct, but if you only have ML and a Moment connect thru a NL/ML converter its work fine
