BeoSound Moment master link connection
This post has 4 Replies | 2 Followers
gabriel
Norway
Posts 42
gabriel Posted: Thu, Mar 26 2015 7:17 PM
I will sell my BS 5 and buy the Moment. Does anyone have experience with the NL-ML converter?
Beovision 7-55" 3D, Beosound 5, Beolab 9, Beolab 8000, Beovision 6, Beo 6, Beoremote one, H8, H2.
lonfred
Posts 200
lonfred replied on Thu, Mar 26 2015 7:57 PM
I would also like to do that but my dealer told me to wait for the multiroom software update that hoppfully soon will come.
frank2u
Posts 80
frank2u replied on Thu, Mar 26 2015 8:12 PM
http://archivedforum2.beoworld.org/forums/p/14245/124588.aspx
There are some minor issues. I bought mine about two weeks ago. It is working very well beside the linkroom issues mentioned in the link.
Chris
Ostend-BE
Posts 1,170
Chris replied on Thu, Mar 26 2015 8:34 PM
gabriel:
The possibility to use the Moment in a masterlink and/or networklink will be coming around 15 May with a automatic software upgrade.
Until that day you can only connect to ONE source.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Normann
Posts 277
Normann replied on Thu, Mar 26 2015 10:17 PM
Chris:
gabriel:
Thats correct, but if you only have ML and a Moment connect thru a NL/ML converter its work fine
Page 1 of 1 (5 items) | RSS
