BLGW connected to Lutron Grafik eye 3500 serie , I try everything i cannot Control the shades or the zone.
I have no problem whatsoever to kontrol the scenes
Anybody have the same problem????
Have you read the Lutron Integration Protocol pdf? If you google "Lutron Integration Protocol" you can find it. This document provides all of the information you need to understand which "component" to use when building your BLGW macros. Sometimes, it is not very intuitive.
Yes I did, and I cannot get it to work. I can control the scene , and that's it.
With my old MLGW was no problem to control of the scene and the zones.
