BLGW
This post has 3 Replies | 0 Followers
claudiu
copenhagen
Posts 193
claudiu Posted: Sun, May 24 2015 12:05 PM
BLGW connected  to Lutron Grafik eye 3500 serie , I try everything i cannot Control the shades or the zone.
I have no problem whatsoever to kontrol the scenes
Anybody have the same problem????
beojeff
USA
Posts 2,012
beojeff replied on Sun, May 24 2015 12:33 PM
Have you read the Lutron Integration Protocol pdf? If you google "Lutron Integration Protocol" you can find it. This document provides all of the information you need to understand which "component" to use when building your BLGW macros. Sometimes, it is not very intuitive.
claudiu
copenhagen
Posts 193
claudiu replied on Sun, May 24 2015 12:48 PM
Yes I did, and I cannot get it to work. I can control the scene , and that's it.
With my old MLGW was no problem to control of the scene and the zones.
mjmedlo
Posts 922
mjmedlo replied on Mon, May 25 2015 12:37 PM
Will the blgw not recognize the Lutron button presses? As inbuilt triggers?
Page 1 of 1 (4 items) | RSS
