Lintronic RT-238
jkhamler
Posts 286
jkhamler Posted: Tue, Jun 5 2012 9:54 PM
Wanted, please :)
Jonathan
Chris Harrison
Peak District
Posts 381
Your not the only one.  I ended up buying a beo5 and programming various non B&O products instead.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
jkhamler
Posts 286
Hi Chris, just wondering is it straightforward enough to program? (My day job is programming so hopefully it's not too difficult). Is it feasible to be able to control a few things - Sony Bravia, Yamaha receiver, PS3, FreeSat etc all from a Beo4 for example? Thanks, Jonathan
Chris Harrison
Peak District
Posts 381
Sadly not with a beo4. However with a beo5 you shouldnt struggle too much. You need the config software of which is available. I control a Ps3, LG TV, lutron. Dual dimmers, twig lights via a remote on/off plug. Any questions do ask. I do not have a bang and Olufsen tv at the moment so struggling to control the sky hd box. I've not figured that one out yet!
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
