Wanted, please :)
Jonathan
Your not the only one. I ended up buying a beo5 and programming various non B&O products instead.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Hi Chris, just wondering is it straightforward enough to program? (My day job is programming so hopefully it's not too difficult). Is it feasible to be able to control a few things - Sony Bravia, Yamaha receiver, PS3, FreeSat etc all from a Beo4 for example? Thanks, Jonathan
Sadly not with a beo4. However with a beo5 you shouldnt struggle too much. You need the config software of which is available. I control a Ps3, LG TV, lutron. Dual dimmers, twig lights via a remote on/off plug. Any questions do ask. I do not have a bang and Olufsen tv at the moment so struggling to control the sky hd box. I've not figured that one out yet!
