Dear members,
just to make sure: which material are the surrounds of the Beolab 3 made of? Rubber? How can they - if at all - be cleaned?
Greetings,
Kai
Hi Kai,
I think they are either painted plastic or non-ferrous metal. Certainly not rubber. I just use a general furniture polish on a very soft, clean cloth.
Dave.
Does this help ?
http://archivedarchivedforum2.beoworld.org/forums/t/2973.aspx
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Ah, sorry. My bad English. I didn't mean the alt but the three woofers with their membranes and surrounds.
OK, I understood 'surround' as the casing material. My problem - not your English.
The outer flexible ring is obviously a rubber surround. The equivalent of the 'cone' on the speaker, or the inner/centre circle feels like a kind of plastic on mine.
Again, I have used a soft cloth slightly moistened with dilute liquid detergent /water or the furniture polish.
Thanks Dave. I will do so too.
