hi my cdx left hand side door hinge has snaped can this be replaced?and are parts easy to get thanks
a solution to this problem has been presented earlier:
http://archivedarchivedforum2.beoworld.org/forums/t/14522.aspx
If you search the forum, there might be similar thread as well: perhaps some other parts of the hinge are prone failure too. So, of course, check were the problem really lies first..
good luck!
guillaume
