beogram cdx
lotus73jps
Posts 141
lotus73jps Posted: Sun, Apr 26 2015 12:26 PM
hi my cdx left hand side door hinge has snaped can this be replaced?and are parts easy to get thanks
hamacbleu
Québec, Canada
Posts 194
hamacbleu replied on Sun, Apr 26 2015 12:39 PM
a solution to this problem has been presented earlier:
http://archivedarchivedforum2.beoworld.org/forums/t/14522.aspx
If you search the forum, there might be similar thread as well: perhaps some other parts of the hinge are prone failure too. So, of course, check were the problem really lies first..
good luck!
guillaume
Page 1 of 1 (2 items) | RSS
