I have couple of those "D-Link DSP-W215" and I would like it very much to control it from beolink gateway.
Anybody have have a idea how to do so??
I have found this link on the Internet, I don't know if can help.
http://www.devttys0.com/2014/05/hacking-the-d-link-dsp-w215-smart-plug/
Thank you very much
NO RS232, can be controlled from one D-link app
This looks like it could certainly be controlled using a custom string. In setting up the custom string, you would need the IP address of the device and the port to use. If you get this working, please do share the custom string! Screen shots work best when sharing code on the forum. Just typing the code into a post can create odd results.
