Beolink Gateway
claudiu
copenhagen
Posts 193
claudiu Posted: Mon, May 4 2015 11:37 AM
I have couple of those  "D-Link DSP-W215" and I would like it very much to control it from beolink gateway.
Anybody have have a idea how to do so??
I have found this link on the Internet, I don't know if can help.
http://www.devttys0.com/2014/05/hacking-the-d-link-dsp-w215-smart-plug/
Thank you very much
mjmedlo
Posts 922
mjmedlo replied on Mon, May 4 2015 12:23 PM
Does it have RS 232 ?
If so you should be able to.
claudiu
copenhagen
Posts 193
NO RS232,  can be controlled from one D-link app
mjmedlo
Posts 922
mjmedlo replied on Mon, May 4 2015 5:13 PM
Problematic I'd say.
Did you try BeoCare?
beojeff
USA
Posts 2,012
beojeff replied on Mon, May 4 2015 10:19 PM
This looks like it could certainly be controlled using a custom string. In setting up the custom string, you would need the IP address of the device and the port to use. If you get this working, please do share the custom string! Screen shots work best when sharing code on the forum. Just typing the code into a post can create odd results.
mjmedlo
Posts 922
mjmedlo replied on Tue, May 5 2015 3:30 AM
I've had a heck of a time with Ip control.
The custom strings can be cumbersome. However.. If this has an IP address then you should be able to control it.
Rs232 However has been rock solid for me so far!
Page 1 of 1 (6 items) | RSS
