I'm struggling to set up my Beolab 6000 speakers to my 7.40 tv can anybody help?
I have a mk4 7.40 TV with its centre speaker! I am wanting to add two front 6000 speakers!
KeithMM:I have a mk4 7.40 TV with its centre speaker! I am wanting to add two front 6000 speakers!
BeoNut since '75
Here is what is under the rear connections cover panel:
Here are the system options on the configuration many for SOUND
If you need the next level of detail download the manual from this site if you are a paid member or from B&O
Final step is to add the SPEAKER soft button to the options under the [LIST] hard button on your Beo4 so you can switch between these speaker modes:
SPEAKER 1 ... Sound in the centre speaker only.
SPEAKER 2 ... Stereo sound in the front speakers. Subwoofers are active.
SPEAKER 3 ... The centre speaker, front speakers and subwoofers are active.
Enjoy !
Just to add if OP has an older Version (MK I or MKII without BS3):
Beolab 7 (Center Sound bar):
Beolab 6000 as Front speakers:
Many thanks for that:
6000 Daisy chained and plugged into the No2 sound panel.
Went into Menu > DTV SETUP > OPTIONS > SOUND >
Then it shows me
SOUND SETUP: Sub Menu ADJUSTMENT SPEAKER SETUP LISTENING PRESETS SOUND SYSTEM AST ON/OFF
I've sort of worked between the sub menu but they are still not working, although the green light on the speakers does light up during certain aspects of the process, but having gone through the process and returning to the tv they switch off!
I'm obviously doing something wrong! :-(
You probably havent 'stored' the new settings before leaving the Setup menu.
If not, the tv returns to the former settings.
Eclipse 65V1-32Beosound M5Essence MK2BLI
Thanks for all your help .... greatly appreciated! Loving it
now wondering where I put the IR connector to work the sky HD Box!
KeithMM:now wondering where I put the IR connector to work the sky HD Box!
If you use a flashlight of some kind, you can often locate the ir-receiver (as a 'red spot') behind the front panel of the box.
