Setting up Beolab 6000 to a beo 7.40 TV
This post has 16 Replies | 0 Followers
KeithMM
Posts 11
KeithMM Posted: Mon, May 4 2015 9:57 PM
I'm struggling to set up my Beolab 6000 speakers to my 7.40 tv can anybody help?
kallasr
Germany
Posts 2,562
kallasr replied on Mon, May 4 2015 10:54 PM
do you have any other speaker (beolab 7) already attached to the tv or are the beolab 6000 the only speakers to be used?
Ralf
PS: If you download the manuals from the bang and olufswn website you will find all info needed....
Dave Farr
France
Posts 2,283
Struggling in what way? A bit of an explanation as to what the problem actually is would help.
Dave
KeithMM
Posts 11
KeithMM replied on Tue, May 5 2015 10:34 PM
I have a mk4 7.40 TV with its centre speaker! I am wanting to add two front  6000 speakers!
elephant
AU
Posts 8,219
elephant replied on Tue, May 5 2015 11:49 PM
KeithMM:
If you already have the two speakers all you need is power cables and two of any one of the three types of B&O power link cables.
Remove the 7-40's rear panel and plug the two power links into positions 2 and 3.
Or if you are daisy-chaining the 6000s just plug the first into position 2.
Set the switch on each 6000's base plate - one to LEFT and the other to RIGHT.
Then use the BV7's system to configure the speakers.
BeoNut since '75
elephant
AU
Posts 8,219
Here is what is under the rear connections cover panel:
BeoNut since '75
elephant
AU
Posts 8,219
Here are the system options on the configuration many for SOUND
If you need the next level of detail download the manual from this site if you are a paid member or from B&O
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Tue, May 5 2015 11:58 PM
Final step is to add the SPEAKER soft button to the options under the [LIST] hard button on your Beo4 so you can switch between these speaker modes:
SPEAKER 1 ... Sound in the centre speaker only.
SPEAKER 2 ... Stereo sound in the front speakers. Subwoofers are active.
SPEAKER 3 ... The centre speaker, front speakers and subwoofers are active.
Enjoy !
BeoNut since '75
kallasr
Germany
Posts 2,562
kallasr replied on Wed, May 6 2015 10:25 AM
Just to add if OP has an older Version (MK I or MKII without BS3):
Beolab 7 (Center Sound bar):
Beolab 6000 as Front speakers:
KeithMM
Posts 11
KeithMM replied on Wed, May 6 2015 6:39 PM
Many thanks for that:
6000 Daisy chained and plugged into the No2 sound panel.
Went into Menu  > DTV SETUP > OPTIONS > SOUND >
Then it shows me
SOUND SETUP:  Sub Menu   ADJUSTMENT    SPEAKER SETUP    LISTENING PRESETS    SOUND SYSTEM     AST ON/OFF
I've sort of worked between the sub menu but they are still not working, although the green light on the speakers does light up during certain aspects of the process, but having gone through the process and returning to the tv they switch off!
I'm obviously doing something wrong! :-(
Millemissen
Flensborg, Denmark
Posts 14,680
You probably havent 'stored' the new settings before leaving the Setup menu.
If not, the tv returns to the former settings.
Seanie_230
UK
Posts 2,278
Hi Keith
Glad we sorted it on the phone. Start with speaker type then roles.
Lastly we had to change default video from 1 to 3 and we were there.
Remember to check SKY HD Dolby is set to HDMI.
Glad your enjoying my old 7-40 I love my 7-55
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
elephant
AU
Posts 8,219
Good work Seanie !!
Thanks Kallasr for the earlier versions' diagrams !
BeoNut since '75
KeithMM
Posts 11
KeithMM replied on Sat, May 9 2015 6:34 PM
Thanks for all your help .... greatly appreciated! Loving it Smile
KeithMM
Posts 11
KeithMM replied on Sat, May 9 2015 6:50 PM
now wondering where I put the IR connector to work the sky HD Box!
elephant
AU
Posts 8,219
elephant replied on Sun, May 10 2015 1:37 AM
KeithMM:
In my back panel picture each of AV1 AV2 AV3 and AV5 has a PUC min jack port; in Kakkasr's post of the earlier model these are grouped together as IR controls 1, 2, 3 and 4 with their mini jack ports.
The associations of PUC/IR to a particular AV should be in the OPTIONS menu.
Where you sticky tape the blaster eye on to your sky box will be for you to figure out :)
I found ours on the FOX upgrade by holding the plaster close to where there seemed to be a change in the shiny black front plastic's detailing ( indicating perhaps the presence of a masked port ) and testing by firing Beo4 changes to see if the FOX receive blinked.
I then went through trial and error in the OPTIONS setting to find the PUC control emulator that best responded by having the majority of the keys responding.
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
If you use a flashlight of some kind, you can often locate the ir-receiver (as a 'red spot') behind the front panel of the box.
Page 1 of 1 (17 items) | RSS
