i have a beo vision 7 that used to be connected to the sky box with what looks like an infrared connector. When I upgraded my box to an HD box this no longer works. I can now only use the sky remote which is no good in other rooms. Is this a simple device purchase or will I need an engineer. Thanks
I have beo4 and beo 6 remotes beovision11 puc Thompson hd version2
works no problem
You haven't specified which Sky box you had originally: Sky Digital or Sky+. Neither of these remotes will work properly with Sky+HD. Also note that there are two versions of Sky+HD software available to be installed into the Set Top Box controller of your BeoVision 7.
You need to have a look at the list of boxes available in the set up menu of your set. If Sky+HD (usually listed as Thomson Sky HD) isn't there, you will need somebody to install a new list via the service tool. Not something you can do yourself unless you have access to the B&O service tool.
Opman
